KESS908SPS00 Kitchen aid oven door locks
Géraldine
Florida
KESS908SPS00
Someone turned on the self clean cycle on my oven which I didn’t want to be used so I cancelled it when it was already mid cycle. Since then the door couldn’t fully close and the oven wasn’t heating up. I found a tread on this website that helped me remove the door latch, rotate it slightly and now my oven heats up again and the door closes fully. ONLY now the door locks every time I close it. I prop it open with a knife pushing the latch to the left but it will lock again every time the door is closed. I already turned off breakers. Not sure how I can fix this next issue !
At least my oven heats now but having to use an knife to open the oven every time is not the best solution either…
Any help much appreciated
I'd let the door close and lock.
Set a clean cycle, let it start and then cancel it.....hopefully this will reset the control and lock.....fingers crossed.
jeff sr.
