KFGD500ESS01 Top broiler works/bake does not - after replacing new igniter
Jean Moser Fraunhofer
TX
KFGD500ESS01
Double oven - top oven broiler works, bake does not. Replaced new igniter and bake still doesn't work. What next?
More information required
Model Number: KFGD500ESS
Are there no numbers at the end of the model number? eg. KFGD500ESS_ _
What exactly doesn't work about it? Ignitor isn't glowing? The burner just won't ignite into flame??
You can read about how common gas oven ignition systems work and the observations and tests necessary to start diagnosing problems with them at the following link:
LINK > Understanding Gas Oven Ignition Systems
Jean Moser Fraunhofer said:
Model No. KFGD500ESS01
[Replaced new igniter and] Igniter is not glowing on bake, only on broil.
A new ignitor should rule it out as the possible cause... assuming you replaced the bake ignitor and not the broil ignitor.
As explained at the link previously supplied that would leave the oven gas valve, the control or the wiring between those components as the possible culprits for your symptom. The bake side of the oven valve should be able to be ruled out with a simple continuity test.
LINK > Oven Gas Valve/Regulator Asm. WPW10546238
If the control is responsible, a new replacement may not be available.
