Bellock159
- KFGU766VSS00
- KitchenAid
- 1-5 years
I received this cooktop second hand from a house renovation. It is a natural gas cooktop with city gas coming into the house. Only 2 (the center and top left) of the 5 burners light completely. When igniting each burner lights quickly then half of the flame will go out and the igniter will try to reignite the gas until it locks the gas value. I have cleaned the burner heads and the caps very well where no visible debris is on either. The caps have slight movement when placed on the burner heads but are sitting correctly on each head. I have removed each orifice and inspected to no blockage is occurring.
It is clear the prior owner used the main center burner the most (I assume this problem has been going on for some time).
I appreciate any suggestions or help with diagnosing this issue. Thank you.
