KFIS20XVMS00 KitchenAid, new control board will not enter programming mode
Danno1
KFIS20XVMS00
The ice and water dispensers stopped working so I installed a new main control board fixed that problem.
The problem is that it will not enter program mode.
What works:
1. Start with display showing PE0 000 FLASHING
2. press water and the Lower Left (LL) button
3. release the water button
4, hold LL for 3 seconds
5. Display shows PE STEADY
When I release the LL, the display reverts to step one, thus will not enter programming mode. It is supposed to display PE0. 000 STEADY when it enters program mode.
Solutions???
Unplug the machine for longer than 60 seconds then restore power. Carefully follow each step
NOTE: The Program Code is located on the Model Serial Plate on this unit after the word Code.
1. Press and hold the Door Alarm Keypad.
2. Press and hold Freezer Temperature DOWN /- Keypad within 3 seconds.
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
5. Entry is confirmed by pressing the Freezer Temperature DOWN /- Keypad once more.
6. The control will display the current Program CODE. This value should be validated with the Program CODE printed on the unit serial plate.
NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
7. Press the Refrigerator Temperature UP /+ Keypad or Refrigerator Temperature DOWN /- Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature UP /+ Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature DOWN /- Keypad until the Program CODE begins flashing indicating it has been saved.
NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program CODE of 0000).Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this process should be repeated.
The Programming mode can be exited at any time by pressing Door Alarm key for 3 seconds or will exit if unattended for four minutes.
