KFIS29BBMS02 - most lights not works - Happy Fathers Day!
thisdude
Cape Cod
KFIS29BBMS02
7 of the 9 lights in the refrigerator are not working.
All of the lights in the freezer have stopped working.
This has occurred over the past 2 weeks. It started with 2 of the lights in the refrigerator failing and has continued.
Is there a fuse that could be causing this?
TIA!
Happy Father's Day!
All these LED lights are in series, if the leading one in series goes out, the whole section goes out as well.
Which are the two that are still ON? The Top ones? TOP 1 and TOP 2? Actually it looks like from your wiring diagram TOP 1 and TOP 2 are both in your ice box(where your ice maker is located).
Here's the LED module for your model you can order(all use this same LED module):
Light Assembly W11205083
thisdude
Cape Cod
The left most 2 lights on in the "ceiling" of the refrigerator still work - the other 6 are out, as is the light in the freezer.
I'd like to try and take out a non-working LED and install it in the socket of 1 of the 2 working lights. If the light works, then it's a problem in series, correct?
OK, how do I remove the LED light? The rubber gasket is very tight. Is there a trick to removing these?
Ok, Take the freezer LED module out and put a good LED Module in its place, that should make the remainder of the TOP lights come on.
Watch this video: LED Module Remove and Replace Video
