FIXED KFIS29BBMS03 KitchenAid Refrigerator - freezer lights out
Pabst113
South Carolina
Jake-
I have a similar issue with my Kitchenaid model KFIS29BBMS03 where the LEDs stopped working in the Freezer, all 4 refrig side lights and the right side top lights. The 2 ice maker LEDs work fine as well as the deli drawer.
I switched the ice maker LED with the freezer LED but still no change.
any thoughts?
Here's the FREEZER LED Module for your model: W11130208
The Freezer LED is in series with the TOP right side 3 LED's in the refrigerator section.
Here's the 3 right side TOP refrigerator LED modules that are in series for your model: W11203918 Module Its comes with the 3 modules and the wire connector.
The LED power supply board/driver in the machine compartment by the compressor supplies 14 Volts DC to each individual LED module. Unplug the machine and remove the LED modules that are not working. Restore power and check for 14 volts DC at the module connector FOR the 3 on the right side TOP. Meter indicates 14 volts DC = replace the module. Any other reading = replace the LED power supply.
All 3 combine into just the 1 connector.
Excellent.(y)
Here's the UPPER LEFT REFRIGERATIOR SIDE LED Module for your model: W11130208
