KGCT365TWH0 All burners ignitors click/spark after burner turned off
David G
San Diego, CA
KGCT365TWH0
After using one of the cooktop burners and then turning off the burner, all burners continue to click/spark for about 15 minutes then stop. The only happens with when I use one of the burners. Any suggestions on what I should try replacing first? Spark electrodes or spark module? Or is this a grounding issue?
David
Many/most parts for this unit are NLA so be careful what you spend on it!
Spark module would be a good place to start after inspecting the ignitors, make sure the burner caps are properly in place.
whirlpool-spark-module-0-wp4454392-ap6009457_01_m.jpg Spark Module
David G
San Diego, CA
Thanks for the quick reply. Could you suggest how I should access the spark module? Do I remove the top of the unit?
David
Spark module is in the bottom base.
It does look easier to remove the whole things, remove top to access underneath.
