KGRS308BSS Kitchen Aid Oven Won't Ignite
robtdam
Illiniois
KGRS308BSS
When I try to turn on the oven, I hear the igniter click for about 5 seconds then quit. I can smell the raw gas so I know there's gas flow. But for some reason the igniter is failing to ignite the gas. Any ideas?
Rick helped you here:
What was the result?
Also we need the complete model number, your missing the last digit.
Here's the results I get:
KGRS308BSS0
KGRS308BSS1
KGRS308BSS2
robtdam
Illiniois
KGRS308BSS0
I replaced the electronic control board about 3 months ago for $320. So far the original problem has not recurred.
Thanks! It sounds like the spark module is bad.
You can use a multimeter to measure between Red/White (#6) wire and the White (#4) wire on the spark module when set to bake. You should have 110-120 VAC. Then check broil the same way only measure between BU/W (#7) and W.
Here's the spark module for your model:
WPW10331686 Spark Module
