Gary_C
- KGRS505XSS01
- KitchenAid
- More than 10 years
I'm trying to help a neighbor her oven. The larger, lower oven works fine, but in the upper oven, which she uses 90% of the time, neither the bake or broil burners will gas-up/turn-on. I don't smell any gas at any time, but both ignitors glow orange/hot when turned on. I could not move the oven to try to find a tech or service sheet. But I found the assembly drawings online, and see there's a "Valve/Regulator" (PN W10293834) that controls gas flow to BOTH those burners. That part is circled in the attached drawing and I also included a picture of the replacement part found online. But all indications from online searches say the valve/regulator (also called safety valve maybe?) almost never fails, and they suggest the problem is much more likely to be the ignitors--even though they appear to be fully heating up. Seems unlikely to me that both ignitors would be failing.
I haven't found an electrical drawing yet, so I don't understand exactly how that works. I'm assuming the control board switches a relay to turn on the ignitors. Maybe the heat from the ignitor is supposed to somehow trigger this safety valve to open? I think there would be separate electrical controls for both those ignitors. Also, since that part is very expensive ($200-$400 depending on source), I don't want to guess and find out that's not the problem.
I found this youtube clip online that seems to be directly related to the issue:
Does this seem like the best next steps? To do all that I'd have to move the oven away from the wall--assuming there's enough gas line to even allow that. So i was wondering if there's a way to run "diagnostics" from the control panel, like in many newer appliances, so I can be more confident, before trying to help her move this beast of an appliance? If diagnostics mode exists, how do I initiate it, and would I expect it to catch or ID this type of fault? Even though the lower oven works, she's hosting her family for Thanksgiving dinner, and is nervous about not having this fixed by then.
Thanks a lot for your time and any suggestions.
Added complete model number
