KGSS907SSS01 Burners do not light
Bill23
Santa Barbara, CA
KGSS907SSS01
This is too strange. When you turn each burner to the light, gas starts at the burner and the broiler sparks (not the burner). There is no gas at the broiler just a spark.
What is going on? I did the off, off, start and the clock code is 01 01.
Hi Bill, that is something I don't see everyday.:)
To diagnose it, access the module, disconnect the J1 connector from the module. With a multimeter, set for 120 VAC, insert the test probes into pin #4(white) and pin #9(red/black), then turn each knob to the "lite" position, You should read 120 VAC across the wires on each test. If so, your switches and wiring are OK, and you'll need the spark module.
Here's the DSI Spark Module Board for your model:
Spark Module WPW10331686
When you click the DSI Spark Module part link you will see a video to replace/access it, but don't remove the DSI board when testing it.
