FIXED KHMC1857WSS0 Error F3H
David G
San Diego, CA
KHMC1857WSS0
The microwave heats fine in the cook mode, but when I try to use the popcorn or potato button error F3H is displayed. It seems the humidity sensor needs to be tested and perhaps replaced. I'm not sure how to access humidity sensor? I see it on a parts diagram, but none of the diagrams who how/where to access the sensor. Is it accessible from the inside or from the top?
David
David G
San Diego, CA
Hi Rick,
Thanks for the picture. I removed the cover and found the sensor, which was by the fan. I wasn't able to test the sensor because all the wires terminals are contained in the part and the wires are contained in a braided sheath that runs to the plugin at the control board. I'll just go ahead and try a replacement part and see if that solves the problem.
Thanks again,
David
Actually that is the test for that sensor. This is from the tech sheet:
Connect a new humidity sensor to the electronic control (at P1) then plug in microwave oven or reconnect power.
If no failure code appears when starting sensor function, unplug microwave oven or disconnect power and install the new humidity sensor.
If failure code appears when starting sensor function, unplug microwave oven or disconnect power and replace the electronic control.
David G
San Diego, CA
Rick,
I replaced the humidity sensor and I no longer get an error when trying to cook with the sensor modes.
Thanks again for your help!
David
