FIXED KHMS2050SSS0 Kitchenaid microwave touch panel issues; error code f9,Q
Sterling
Honolulu, HI
KHMS2050
This is a microwave hood combo-all aspects working except touch pad. It beeps sporadically when not in use and touch pad doesn't respond. Unplug & re-plug fixes this for 1 or 2 uses, then it's back to the stated issues. Error code is f9, Q.
I have read that I should first check wiring connections but can not find how to access that or what these error quotes mean.
I have read other accounts of this exact same problem on this and other forums, but no fix.
Thank you for any assitance... and for this fantastic site!
Sterling
Sterling
Honolulu, HI
touch pad.
-after unplug/plug the display reads "set clock yes/no"
-i can enter cook time & microwave functions normally
-w/in a few minutes the sporadic beeping resumes & display reads "error code f9, Q"
-touch pad doesn't respond & unable to start microwave
Sounds like a bad touchpad. I don't have the tech sheet for that model. Can you post a copy of yours here?
Here's what it says on the tech sheet for F9Q :
1. Unplug microwave oven or disconnect power.
2. Check the communications cable from UIB to the touch panel board.
3. Replace all parts and panels before operating.
4. Plug in microwave oven or reconnect power.
5. If problem persists, unplug microwave oven or disconnect power.
6. Replace the door control assembly.
7. Replace all parts and panels before operating.
8. Plug in microwave oven or reconnect power.
Sterling
Honolulu, HI
Jake; thanks for tracking this. the tech sheet is very helpful -
Im gonna open her up and check the wires. connecting UIB to touch panel board as it suggests.. its likely str8 forward, but i prefer to have some instructions to review - so i know what to remove & in what order - does such a thing exist?
thanks again & i will post progress & findings here.
I couldn't locate the service manual for this model that would show you how to take it apart.
I can ask our other tech. bigbuck is he does.
Ok, thanks for trying bigbuck!
There's 3 screws on each side of the door. Remove those screws and the choke (inside door) will unsnap from around the door.
Thanks Rick!
Sterling
Honolulu, HI
so, back to my original question...anyone know where/how to access this connection between UIB & Touch Panel Board?
I see on tech sheet where parts are located - but still don't know if I open/disassemble the door or the inside/outside or unit - that's all I need to know - don't want to take this whole thing apart - just want to check this connection - can't find this answer anywhere and getting fairly frustrated. BTW, Kitchenaid was zero help.
pretty please, if you know, share.
......can't find this answer anywhere and getting fairly frustrated.
I hear ya! You should be glad you're not on this end....Lol. For example, In your first post you said:
So I asked you, unplugging the touchpad or unplugging the microwave? You said:
touch pad. -after unplug/plug the display reads "set clock yes/no"
This is the connection I would have told you to check but you already did. The UIB (User Interface Board) and touch panel are both in the door. If you unplugged the touchpad from the UIB and it worked a few times the touchpad is bad. But now I read your last post and you're asking:
So now I'm thinking, maybe someone made a mistake. Just to be sure, What fixes it for 1 or 2 uses, unplugging the touchpad connector or unplugging the microwave power cord? Yes, sometimes it can be very frustrating.
... but still don't know if I open/disassemble the door or the inside/outside or unit
Maybe this diagram I made will help you. Use a flat paint scraper to unsnap the choke from around the door. Start in the corner by the top door hinge. If you need to remove the door from the frame there's 3 screws on each side and 2 on the bottom. Once you can access the three control cover screws you'll be able to access the touchpad and control
Sterling
Honolulu, HI
Ah shoot.. it was me, I made the mistake... here's the thread snag:
-ME: 'plug/unplug fixes this for 1-2 uses
-YOU: touchpad or microwave?
-I INTERPRET: fixes touchpad or microwave?
Didn't make sense, so I replied by clarifying what happens upon unplug/plug
So, let's back up. I unplugged the microwave from power outlet. I unplugged it, waited 30-60 seconds, then plugged it back in which seemed to reset it, then I could use the microwave once or twice, then the error code pops back up and random beeping resumes.
today i attempted to disassemble the microwave door- I started with the 3-screws to the side of the handle only visible once the door is opened; the plastic they were threaded through disintegrated and fell in pieces as I unscrewed. I removed the 2 screws on the bottom of door - don't see any screws on the top of door or anywhere else on door - and it seems removing those 5 has no effect - hence my frustration.
Thank you for the incredible diagram - very thoughtful of you. I will take another crack at it tomorrow using that and your instructions as guide... thanks so much, I'll post progress.
*I am in earliest time zone which is why you won't see my replies right away
rickgburton said:
......and the choke (inside door) will unsnap from around the door.
It's always best to start with step one. You need to remove the choke first. I wasn't sure about the screws on the sides and bottom so for now just ignore them. One thing Whirlpool is good at is keeping the disassembly and installation of components the same across models. The KOMS1550 microwave also has the keypad and UI board in the door. I'll show you how that one comes apart and even if the parts don't look identical they will look similar. That should get you started.
Unsnap the choke from the door using a flat paint scraper.
Once the choke is off, lift up on the door latch arm and unhook the spring and set aside.
From here you'll need to check for hidden screws holding the control bracket. You'll see something similar to this:
When you get to the control board these are the two connectors you need to check. Clean the end of the ribbon connector with a clean pencil eraser and make sure it's seated all the way in the connector. Look for any pinched wires or pins backing out of the connector. Look for any discoloration on the board. Your parts will look similar to these
NOTE: Some machines are easier to service when removed from the installation and the cover removed and on some it doesn't matter. On some machines it's easier to remove the door from the machine to work on it and on others it doesn't matter. Your choice.
