kirkland won't turn on?
redline808
gone
-major brand-
Less than 1 year
I didn't know where to post this....I have a kirkland refrigerator that was working fine, then it quit, meaning the compressor does not turn on nor does the fan in the freezer, but if left plugged in for a few days, it would re-start on its own and be good for a while then the same thing would happen again. now it will not come back on? the model number has been cleaned off the tag. it is a shorter model. 65 inch tall and no handles on the doors.
any thoughts?
thanks.
I put your thread in the Whirlpool forum, since Kirkland is made by Whirlpool.
Sounds like your cold control thermostat is bad, but without a model# I can't look it up for you.
Does your model just have the normal 2 knobs to control the temps?
Ok, then thats likely your cold control thermostat. You'd have to unplug your refrigerator and remove it and it should have a part# stamped on it.
The control console that holds it in place likely has 2-4 screws that mount underneath it and the control console drops down from the ceiling then you have access to remove it.
redline808
that was the problem. I swapped out the entire unit mounted to the ceiling with another and it works. took all of 5 min. thanks!
Excellent, good job.:)
What was the part#?
redline808
new problem. with the new part, the compressor turns on now but the coils don't get cold? blows warm, was plugged in all day.
Need part# of what part you installed.
redline808
where is the part #? i changed the all the pieces in the panel connected to the ceiling. timer, switch, light bulb socket, i replaced it all as a unit.
Ok, then the part# should be located on the package it came in.
You have to understand I'm working blind here without a model# to go by.:)
redline808
i replaced it with a used piece from another fridge. is there a part# anywhere on the timer?
Yes, the timer should have a part# on it.
redline808
the timer i took out. part #2188371
the timer i put back into the fridge was part #2162044
redline808
photos of the old unit and timer, photos of the new used unit and timer.
let me know your thoughts.
thanks.
Yes, thats correct.
Or the cold control thermostat.
You may want to have a tech. come out to give a second opinion though.
redline808
ok, got my new timer. but i dont know how to wire it? i dont have a wiring schematic, so i dont know where the black wire goes. can you help?
I tired to get the model # off the kirkland, but like i mentioned before, it was smudged.
what i could make out was. 4CKXKQ01
It came with an instruction sheet of where that wire goes:
redline808
yes it did, the problem i am having is, i dont have the factory schematic to make a comparison. would you know which way to set it up?
