kirkland won't turn on?
Ok,
If the timer has a WHITE wire going to it ,the black timer lead goes on # 1
Anything else goes on # 2
[FONT=arial, helvetica][/FONT]
[FONT=arial, helvetica]Jake
[/FONT]<!--mstheme--><!--msnavigation-->
You should have 4 wires that go to the defrost timer in a plastic connector that plugs into the 4 defrost timer terminals, do you see a white wire in any of those 4 wires?
redline808
photos of the old unit and timer, photos of the new used unit and timer.
let me know your thoughts.
thanks.
Photo #1 in post #14 is of the unit I threw away. I don't see any white wire going to the timer. so I think it looks like the black wire will go to #2 pin.
Yes then #2 pin.:)
Ok, sounds good, keep us posted.
redline808
i installed it, plugged in the fridge and nothing happened? i could hear the timer ticking, so i hand turned it until it clicked, then the fridge turned on, i continued to turn it till the next click and then the fridge turned off, i further turned it until the next click and the fridge turned back on, so that is where i left it. doors are closed, water bottle in the freezer and i will check on it in a few hours.
Ok, yes, don't advance the timer anymore, let it work on its own.:)
Sounds like you got it, keep us posted.
redline808
i haven't check on it again, but 4 hrs ago it was still blowing warm air? i will check on it in the morning. i hope its cold.
Ok, how is it today?
Ok, I really don't know whats causing it, you'll likely need a tech. to come out at this point.
Yes, either the control board if yours is the electronic display or the cold control thermostat if yours has knobs.
