Kitchen Aid KUIS15NRXB0 wiring harness
SalM
Toms River
KUIS15NRXB0
Ice machine need a major cleaning. While putting it back together, a wire or 2 broke apart in the harness that runs the reservoir pumps.
I do not think it would be wise to try to fix the broken wires.
Can I get some advice & the correct part #?
Looks like you are correct.
SalM
Toms River
Thanks Jake.
How do I get this machine into diagnostics mode?
One assembled, I want to make sure all is correct.
Also, any advise on getting the wire back through the vey tight wire runs?
SalM
Toms River
Thanks. I think this is for the older models. Do you possibly have a newer one? I think mine was produced 2014, based on Info in serial# decoding.
Sorry I don't.
Thanks for adding that. I'm not sure if it makes a difference of not by 3 years, it should.
SalM
Toms River
Fixed!
Wow, there machines can get really gross over a long period of time! And you can't tell until you start disassembling! I completely disassembled the interior of the machine, except for the freeze plate and cleaned everything by hand. Replaced the wiring harness that broke from age in the cleaning process. All back together and working properly.
My advice- Take the top panel off! (like working on a car, sometimes best to remove the hood) Makes working on the machine SOOOOO much easier!
If anyone needs pics or advice, LMK. I am NOT an appliance tech, but have some knowledge.
