Kitchen Aid Oven/microwave combo microwave is dead
jasonrichards
Carlsbad
KEMS308SSS05
Less than 1 year
I have a Kitchen Aid Wall Oven Microwave Combo Model KEMS308SSS05 that is around 2 years old.
Oven works fine
Microwave oven just died with the following symptoms.
-Display works fine and illustrates as if working normally.
-Microwave itself is dormant and silent, no fan, no stirrer/magnatron sound, no light, no turntable.
Two items to note
-we returned home from a week long trip and the oven had error message on both displays. I hit cancel which reset the error message. The problem is likely associated with this as this is the starting point of the dead microwave
-for many months before and after a self cleaning cycle in the oven, the microwave would have a loud fan noise when operated which research sounded like a bad stirrer.
I love fixing appliances and have no problem digging into this one but before I pull it from the wall I was hoping to get some feedback of likely issues or things to test.
Many thanks....
Jason
I have only seen a couple of these....and all where a bear to get at many of the parts.
Door switches, door switch keys should be checked.
Fuses, thermostats would be next on the hit list.
See tech sheet attached.
I no longer have access....lets see if bigbuck has one.
I just messaged BB.
Thankx BB....and even on Turkey Day ;)
