KitchenAid Dishwasher KDFE104DSS0 Metal Dust and Error Codes
RussW
California
KDFE104DSS0
I'm getting a film of brown/gray 'dust' on the lower pan and walls towards the bottom of the wash tub. I've tried running Finish dishwasher cleaner, and it did not clear out. Ran several cycles with no dishes and noticed that most times the machine is not filling much above the intake area inside of the heating element when it's stopped/open. I added water during the cycle (about a gallon) and that filled it to raise the float switch. Running extra cycles helped remove some of the film from the walls but not entirely. The film has a metallic smell like steel or ferrite.
I ran the diagnostic cycle on it and it returned the following codes:
8-1 "Open Regen Valve Circuit or Solenoid"
8-2 "Open fuse on control to Regen valve"
In searching for parts I can't find it to determine what the Regen Valve is 🤷‍♂️
Your model doesn't seem to have a REGEN VALVE.
--->FOR MODELS WITH WATER SOFTENER: REGEN VALVE
For that dust issue, look here:
RussW
California
Interesting about the pans/sheets shedding metal or a 'coating' but we hardly ever wash metal or nonstick pans in our machine. The only thing I could say that we regularly wash that is metal would be our stainless silverware, and it does not appear to be rusting.
I understand that my model is probably not equipped with the 'Regen Valve', but why is it trowing a code if that component was not equipped on the machine?
Also noticing that the machine is not filling with water on the 'normal' wash cycle, only enough water to cover the pump intake area, not nearly up to the float valve. If that's happening regularly, I could see there being too much concentrate of detergent in the small volume of water.
That's what I don't know either. Never seen that before myself on my service calls.
Yes, that's possible, usually on these machines they don't fill with much water anyways.
If the amount of water is extremely low, take video of it in the tub and take another video of the normal fill you see on other cycles.
