cannonballmn
- KDFE204ESS0
- KitchenAid
- 6-10 years
I'd appreciate some feedback/guidance on the topic and thanks in advance for any help.
The dishwasher stopped cleaning a few days ago and now, after some debugging, it seems as though the pump is not moving any water internally around the compartment. I had replaced the inlet valve because dishes were not wet inside at all, but that didn't fix it and I found that it was actually pumping water into the unit and opening/closing properly.
It does pump water in and then make sounds from motor area when I start a basic "rinse" cycle. I've jimmy-rigged the door to think that it's closed and haven't seen any water fire around the arms (although with noises). When I end the cycle (or close the door), water does pump out to my sink drain - so this part works. I'm not sure how independent those functions are (moving water around and draining the dishwasher). I'm thinking just a new unit (7 years old) if I need to replace the whole pump mechanism at $300. But if there's any suggestions about other sensors/etc to check, I'm all ears.
Also, does anyone know if the diagnostic interface works with this model? I've tried the 123-123-123, etc and haven't seen the lights come on - but then I think that might apply to other models.
Thanks in advance!
Thanks in advance!
