Kitchenaid Dishwasher KDTE234GPS0 not draining at the end of cycle, but draining completely the next morning when cold...
Michelcp
Tingwick, Quebec, Canada
KDTE234GPS0
Our two y.o. dishwasher doesn't drain at the end of washing cycle, but drains completely the next morning when cold... It washes correctly but there is always water on the bottom... Since it does drain when cold, the hose is not clogged and the pump works fine, wht could be the problem?
Sounds like its a faulty drain pump overheating, preventing it from draining in final drain.
What I do is remove the electrical connector from the drain pump and put my meter leads in each of the two electrical connector slots and when it gets to the final drain cycle, watch the meter, if your meter reads 120 volts and the drain pump is not running, then the drain pump is bad, and it will need to be replaced.
Watch this video to access it:
You can see the 2 brown wires in the video still, that's your electrical connector wires.
W10876537 Pump-Drain
Ok, sounds good.
