- KDTE254ESS2
- KitchenAid
- 1-5 years
My dishwasher has been running without issue for a couple years, until now. When starting a cycle, it fills with water, then stops and turns on the Cancel light. Hot water remains in the bottom of the basin.
So far, I've put it in diagnostic mode, which returned code 4-4 (circulation pump) and 8-4 (drain pump). I manually drained the water and checked the drain filter, it was clear. I then pulled the drain hose and drain pump from underneath and found no obstructions. It appears clear and spins freely. I also checked the drain hose at the garbage disposal end to make sure it wasn't blocked and that was clear.
The circulation pump can't be reached without pulling the unit from the cabinets, which I would rather wait until a new circulation pump arrives before I bother with that, but will if needed.
It seems unlikely that both pumps would suddenly go bad at the same time. Should I be looking at something that manages them both, like a control board? The area under the dishwasher is dry and clean. It still looks new down there so I'm at a loss. Any help would be appreciated!
