jiwaus
- KDTM354DSS0
- KitchenAid
- 6-10 years
I ran diagnostics check, got the following codes. Any suggestions? Thanks
9-1
6-1
8-1
8-2
9-1
6-1
8-1
8-2
fill the water, then stop not running at all. thanksLets start over and forgot the error codes right now, what is the dishwasher doing wrong?
I can see diverter shaft rotating with clicking sound.What does the motor and diverter do in the service diagnostic cycle? Listen for the cam clicking in intervals 15 and 14 of the test cycle.
JakeWait, stop the presses! I just noticed this model has the problematic door vent, that can also cause this problem you are having.
Do this first--->Disconnect all the wire connectors to your door vent and see if it runs through a complete cycle.
Start reading what bigbuck said at post#18 here:
FIXED - KUDE60HXSS5 KitchenAid Dishwasher Fills but then Shuts off
So after successfully running the one hour cycle with the vent wire harness disconnected, I ran the ProWash/ProDry cycle with the vent harness disconnected with 100% success.www.applianceblog.com
Your model uses the exact same door vent. If it runs through a complete cycle and everything is back to normal, then order and replace the door vent assembly.
WPW10469574 Vent
To access the vent assembly you will need a T-15 torx screwdriver: Remove 4 screws (long) across top of door, then remove 10 screws (short) on the sides, then the outer door panel pulls off.
Yes 124.6After the fill cycle check if the wash motor is getting 120 VAC.
OK so the motor is getting 120V and it's not running. Here's the part you need:fill the water, then stop not running at all. thanks
Thanks Rick.OK so the motor is getting 120V and it's not running. Here's the part you need:
Good question. My answer is, I don't know.
