chef951
- KUDC10FXSS5
- KitchenAid
- 6-10 years
Hi I have a KitchenAid KUDC10FXSS5 Overfilling / Leaking from the Float Tube. I have replaced the Float Switch/the water Filling Valve /made sure it was level/ I took apart the float (it is clean) as well as the gasket. I have run it a few times without soap and it still leaks.. any thoughts?
No issues with cycle or water draining out at the end. I did a 'reset sequence' like Jake had mentioned in another post the 123 123 123 and no leaks on that 23 min cycle but, but it did leak on the next regular use with no soap.. could something else be causing the water level to raise higher than it is supposed to? ( I thought possible the fill valve was old and closing too slowly after it got the signal to shut off from the float switch.. Thank you for any ideas..
