- not listed
- KitchenAid
- 6-10 years
Dishwasher sounds like it starts and a pump possibly starts but doesn't seem to be filling all the way as there is just a little water when you open the door after it self cancels but doesn't go through a drain cycle. If you push the cancel drain button it will drain the little water that is visible.
When I run the diagnostics I get error codes as follows: 10-1 6-4 6-6 5-1. I've checked for continuity on the float valve switch and it looks good and the float moves freely. Opening and closing the door will stop or restart so I am assuming the door switch is ok.
The water running to it is warm at water heater temp. Unfortunately I do not know the model number, it was an open box buy that had a leaky tub and when it was replaced it doesn't look like the model number sticker was included. I have attached a picture of the controls and the number imprinted on the door.
