Kitchenaid DW KDFE104HBL0. Spray arms not working. Not spraying water or rotating. I cannot get the correct sequence to reset the dishwasher.
gmarty171@gmail
KDFE104HBL0
The arms are not spraying water or rotating. All filters are clean. I can't get the correct button sequence to do a reset or valid a error code. The button panel is on the front. Tried normal, heat dry 4 times and nothing. It says the DW needs to be in standby mode..??? Suggestions please
Run the SERVICE DIAGNOSTICS CYCLE, and let it run all the way through to reset it back to default.
--->Invoking Service Diagnostics clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle.
Do that and report back.
If the wash motor is still not running, that usually indicates a bad wash motor. To verify that--->You can remove the wash motor electrical connector underneath the dishwasher and measure resistance across the electrical connector on the motor. It needs to read 5-15 Ohms.
Here is the wash motor assembly for your model: W11084656 Motor-Pump
  • W11427956-reva.pdf
Ok, disconnect power to the dishwasher(turn the breaker off to it, or unplug it) then take the main control board out and look to see if you notice any burnt spots on it.
