- KOCE507ESS11
- KitchenAid
- Less than 1 year
We've recently been getting a door error for the microwave, but we noticed that if we held the door shut it worked fine. From reading on here I decided to try to replace the door switches.
When I tested the switched all of them tested good, but I went ahead and replaced the two on the right side, I'm ordering another for the left. Testing the original switches all three tested good and the physical switch all had good movement. Watching closely while closing the door all the switches all engage, but appear to immediately disengage as you can see and hear the click and immediate click again.
Is there a way to adjust the tension so the door remains latched? Or is there some other adjustment I'm missing?
The only thing I see readily would be to find a weaker spring on both sides where the switches are, or replacing the door hinge (https://www.repairclinic.com/PartDetail/Door-Hinge/W10874474/4459956)
Thank you.
Thank you.
