KitchenAid fridge: KSSS36DWX00
cin993
CT
Model
KSSS36DWX00
Hello,
The milk and food is sometimes frosty, so too cold and I can't seem to make it less so with the Temp Control knob.
What are the appropriate temperature ranges for the refrigerator part of my unit? What is within spec?
The Temp Control knob inside the fridge on top has a "Cold" setting and then we can turn the knob to the "Coldest" setting--there is no digital read-out.
So, I put a small $10 digital thermostat inside the fridge to test the temperature.
It reads minimum 32 degrees and maximum 35 degrees and this is on the "Cold" setting. It seems about 5 degrees too cold.
The freezer temp is minimum 1 degree, maximum 7 degrees.
Do you know what the specs are for the fridge temperature? Or how to test the fridge temp gauge to replace if defective?
Thank you very much.
