Kitchenaid fridge not cooling
bearden08
New member
Thomasville, GA
Model
KSRL25FXMS02
I pretty much narrowed it down to the diffuser. When I put a pencil in it, I can feel the air coming from the freezer. However, when I plug in the fridge after is has been unplugged for a few minutes, I can hear the diffuser motor trying to work. Any suggestions?
Kitchenaid KSRL25FXMS02 side by side
You may have a bad air diffuser then, but you may want to remove it and check for an ice blockage inside it first.
You will need to access it from inside the freezer on the top back right side(you may have to remove the ice maker and the air tunnel to get to it.)
You will see it, it has 4 clips that just push-in, then you push the whole assembly out into the refrigerator section.
You gotta kinda push-in and hold those clips in while you push it through into the refrigerator.
Here's the air diffuser for your model you can order here:
Whirlpool W10128734 Diffuser - AppliancePartsPros.com
