ChristopherW
- KBMS1454RSS0
- KitchenAid
- More than 10 years
This microwave is about 15 years old. It mounts in the wall and matches the rest of our Kitchenaid appliances. When in use, it will start and then stop, light goes off, fan stops, timer freezes, then it will start again. Usually worse when hot. Occasionally it will stop every 2 seconds and then run fine the last 30. Several years ago it was doing something similar. I opened up the cabinet and found 2 connectors that were burned. One was the blue wire at the HV transformer, coming from the relay and the other was the white wire from the magnetron thermostat to the cabinet thermostat connector. I replaced both connectors, cleaned up the terminals and it's been fine until a few weeks ago.
Recently, I replaced all the door switches, the HV capacitor and diode. I tested the thermostat on the magnetron which was fine. I'm starting to suspect the cabinet thermostat. I checked it and it was showing 2-3 ohms. I think it is supposed to be 0. The line filter capacitor is one other possibility, but I have not tested it yet. Parts are hard to find. The cabinet thermostat, Whirlpool part #8205652 is NLA. If I had the tech sheet or service instructions, maybe I could find a suitable replacement? I've checked the power coming in, which is fine. I would hate to scrap it over a $10 part. A replacement is about $1700.
Appreciate any insights or advice
