- KDTM404K
- KitchenAid
- 1-5 years
I have a Kitchenaid KDTM404K that's about 2.5 years old that's giving a 9-1 code (not draining). I had this fixed under warranty with a new drain pump after about 11 months. A year later, at 23 months, it happened again and a new drain pump seemed to fix it. It's occurring once again about 4 months later (intermittently at first, more consistently now).
I get the error when running a full cycle. After the error, I can immediately drain using the "cancel" function, and then it works fine on a "rinse only" cycle to make sure the dishes are clear of soap.
I can't imagine the drain pump is bad again, given that it works on the rinse-only and cancel (drain) functions.
Is there something else that could be failing? I have confirmed there are no kinks, blockages, etc. This dishwasher has been super frustrating. I also had the seals for the heating element go out, which leaked water through the floor into my lower level. Last Kitchenaid appliance I buy.
Thanks for any ideas anyone has!
