Kitchenaid KMHS120ESS4 Microwave hood light won't turn off
Lkrav3
Texas
KMHS120ESS4
Our vent hood light was out (or so we thought). I went to unscrew it (not realizing you should unplug the whole unit first) and it lit back up... so I screwed it back in. A few seconds later, it popped/shattered. I then replaced the bulb and now it stays on bright even when you cycle through the low, high, and off switch settings.
I have a new control board on the way, but after a little research elsewhere... I'm wondering if I can't repair the existing circuit board myself. Looks like from the wiring diagram for our model that a TRIAC on the hood lamp circuit is the likely culprit? I opened up our panel to get a look at the existing TRIAC and ordered a replacement BT136-600D that should arrive tomorrow or next day.
Does this sound like a logical step/solution?
Thanks for any help/advice/direction.
Did this end up working for you? I'm having the same problem and don't want to spend $200 on a new control board.
It's so frustrating. I have the microwave, and everything works fine except the light stays on. Is there any issue with just leaving the light on indefinitely? I'd prefer not to spend $200+ fixing a microwave I bought for $350.
I dont think there is an issue just leaving it on. I leave mine on all the time. Maybe we will hear back from the original poster and see if the triac worked.
The original poster reached out and said the triac did fix the issue. If you’re comfortable desoldering and soldering it’s an inexpensive fix. Less than $10 for a triac.
Unfortunately, I have no idea how to solder. I called a few appliance stores and they don't either. I called KitchenAid because it's under warranty but they would charge me $139 to send someone out to verify the issue. So there isn't a path to me fixing this for cheap unless I find someone who solders and works on appliances in San Diego County.
