FIXED Kitchenaid KRFF507ESS01 RC not Cooling but mysteriously is now
smithcrew
San Antonio, Texas
KRFF507ESS01
Hello. I have been fighting a refrigerator side cooling problem for several weeks, and have read many many posts on this forum about this issue, so thanks to all who have contributed to the forum. I have replaced the main control board, did not help. Confirmed the FC and RC thermistors seem to be working (ice bath test for RC thermistor, self test for both from front panel, and ohm out from rear of fridge at connector J5 for both). Self test #4 passes. The RC evap coil will cool. I put a thermocouple on the FC evap air outlet during this test and the air is very cold at 20F or less. The coil has not had ice buildup that I have ever seen. I took the RC apart down to the evap fan also to check for ice and working fan. Fan is blowing fine. Every time the compressor shuts off and the system cycles on again, the RC evap seems to work fine. Once the RC hits the temp set point, the system seems to move to the FC and never gives back to the RC evap. If I power cycle the refrigerator (unplug or breaker), this starts over. RC evap works for first cycle and then does not seem to get the coolant back again. Freezer has worked throughout all of this. At one point, I tapped on the diverter valve to see if it was stuck in FC position with no effect.
UPDATE and delima. After not working for these couple of weeks, the RC is now working fine for the last 2-3 days. In this area where we live, service technician visits are difficult and take a week or so to schedule. I have one scheduled for a visit in three days and am wondering if I should cancel and see how our run of working refrigerator goes. I am concerned that the $200 cost of their trip out here is not going to help, especially now that the problem may be intermittent. I did cancel once already when I hoped the main control board that came in would have fixed it. Any advice would be appreciated.
Sounds like possibly a sealed system problem. That should be covered under your sealed system warranty, for at least 5 years, check your owners manual warranty page to make sure.
What is the Realtime temperature that your freezer thermometer says it it?
If you don't have freezer thermometer you can get the RED Liquid or digital freezer thermometer. Walmart, Target sells them usually at about 10 dollars and they last a lifetime. The temperature needs to be 0 degrees F at all times in the freezer.
smithcrew
San Antonio, Texas
Thank you for the reply Jake. Warranty does say 5 years on sealed system for parts and labor, and parts for 10 years. I will keep my appointment with the technician. I actually saw the refrigerator warm up a bit this morning, to about 46F and likely rising. When I set the freezer to zero, it holds pretty close to that. I just looked and it is right on zero, even while the fridge is at 46F.
I am using a Taylor dial thermometer in both the fridge and the freezer. I also use an ohmmeter with thermocouple input for troubleshooting, so I can move the thermocouple where I want it. I placed it at the back of the freezer to make sure the space around the FC evap thermistor was reading similar to the thermometer I have at the front of the freezer, and they were in good agreement. I will post an update after the technician visit.
Your model has the 3-way valve( aka solenoid/valve assembly) in the sealed system, that might be the cause, yours uses this same one here:
But should be under the sealed system warranty as well.
smithcrew
San Antonio, Texas
Technician is due tomorrow. Unit has been working flawlessly since last posting. Will post what they diagnose and hopefully fix. BTW, also had the side LEDs and freezer LED out and read through one of your previous posts that helped diagnose the freezer LED as the culprit. I shorted across it and the lights in the fridge came on. Ordered the new freezer LED.
Ok, sounds good, let us know how it goes.
smithcrew
San Antonio, Texas
Repairman paid us a visit. After hearing our testimony, he was very baffled. The company had sent him with an inverter for the compressor, but he thought that was likely not the case since the freezer has not had a problem throughout this ordeal. He ran some of the UI diagnostics that I had already run, and they showed all systems good.
He checked the current draw and it was nominal at 1.2 amps, so he felt the compressor was running nominal. Suffice to say, we paid him for the service call and have 90 days to get him back out on that same ticket if things go south on us again.
Everything seems to be working at this time. Fridge is 37F and the freezer is 0F. There is one more tidbit to mention if you have time. I asked him if he had the freezer LED in his truck, and if so, I would replace it and just send the one I ordered back when it gets here, or keep it as a backup.
He brought me what he had, and it was the RC type, not the FC type. I noticed when I ordered the FC LED, it was twice the cost of the FC, and I chalked it up to ruggedized for a freezer temperature, so more expensive. He said he uses the cheaper one in the freezers just fine. I had one of the RC type since I had already ordered one so I installed it and all lights working. Does this sound like a bad idea? They are all working now.
Ok, sounds good, thanks for the update.(y)
Here's that OEM FREEZER LED light module for your model:
Led Light Board W10695459
Here's the parts diagram for the refrigerator section:
(click to enlarge)
#38 is the LED light module for the top left 2 and the side ones: W11462342
I don't know if you can use the #38 ones in the freezer, I've never tried that before myself, I always order and replace the freezer LED with the OEM one KitchenAid says to use and never had a problem.
So if its working as you have it now, then that's fine, but if it goes out again, I'd get the OEM freezer LED light.
smithcrew
San Antonio, Texas
It has been about a month now and the refrigerator has been fluctuating between 28 and 40, all the while with a 37 setpoint. Until yesterday, when it was back up to 50. We called the service company and since we are in the 90 day return window, they are coming out again. By yesterday evening it was back down to 40. The freezer is steady as she goes at -2 to 0. I am not really wanting to blow a bunch more time or money on this problem. It sounded to me during the last visit that they would try something and hope that would work, but they really were not sure what to try. I would be on the hook for the cost of all the tries. Curious if folks would continue trying to save this appliance. I really am not excited about dumping such a new fridge. Is this temperature behavior at all acceptable? I was thinking I could live with the 28-40 since I did not exceed 40, but 50 seems unacceptable.
Since your model uses a refrigerator evaporator to cool the refrigerator, I did locate a service bulletin dated March 2021 about what this problem could be, I'm attaching it below.
Start on Page 2 and Page 3 to see if the evaporator thermistor is the correct position. Lots of members here found it was in the wrong position and reset it to the correct position and it fixed this problem, that evaporator thermistor controls the defrost cycle, thus keeps the temperature consistent when in cooling mode.
IMPORTANT: thoroughly defrost the entire evaporator. Excessive frost and ice build-up could cause future service calls.
1. Check the RC Defrost Thermistor for proper operation and placement.
a. Check resistance of thermistor per tech sheet resistance table.
b. Check Thermistor Location; it should be located as shown in figure 1. The thermistor should be tight and in full contact with the suction tube directly coming out of the Evaporator. Do not damage the paint while installing.
c. If the thermistor has a metal clamp, you may need to use a pair of pliers to gently squeeze the clamp to ensure good contact with the tubing (See Figure 2). Be sure not to crimp the Thermistor while closing the gap.
Also on Page 3 to see if the refrigerator evaporator drain pan is BOWED in the middle.
--->The evaporator drain pan should be seated flat and not bowed upwards in the middle (SeeFigure 4). A bowed drain pan may prevent water from properly draining. Ensure proper alignment of the drain pan. If the pan is cracked or permanently deformed, it must be replaced with one of the pans in the kit.
Here's the refrigerator evaporator drain pan it says to order if yours is BOWED:
And follow the instructions in this service bulletin, it does tell you how to remove it.
  • service-pointer-w11092686-revg (1).pdf
smithcrew
San Antonio, Texas
Canceled the appointment. Will check evap coil thermistor location. Fridge is back to 37 this am. Trying to think through this. If that thermistor is not attached well, it will show a warmer temperature to the system I would think. If the system sees the evap coil as warmer than expected, I would think it would do nothing and you would potentially get ice build up and fridge would warm up. That makes sense to me. What I am struggling with is why the fridge is dropping to 28 under these conditions.
Will post again after I dig into the evap thermistor.
No, your reading that wrong. It says if the thermistor is not attached in the proper place on the evaporator coil, that is the issue.:)
smithcrew
San Antonio, Texas
Possibly last update. I decided to let things go for a bit and we are fluctuating between 30ish and 37, for the most part. Our setpoint is 37, so still not really sure why we go colder than that, but would rather be colder than warmer. Thanks again for the help.
Ok, thanks for the update.(y)
