LongThought
- KRMF706ESS01
- KitchenAid
- 1-5 years
Hello. To be honest, we've had issues with this unit making ice consistently since we purchased it new, approximately 3 years ago. It seems to work okay for a while, then will stop making ice for no apparent reason. It will occasionally just start making ice again on it's own! Several tech visits, while it was under warranty, didn't reveal the issue. We were told that units with ice makers in the door are problematic in general, and that all they could recommend was to lower the temperature in the freezer to make sure it was cold enough to operate properly. The freezer is currently set to -5 degrees, and the fridge is at 34. I haven't measured the actual temps for either, but things in the fridge are cold, and items in the freezer are frozen solid. And I can manually make ice, see below.
Using the tech sheet, I've performed these diagnostic tests, with the following results:
Service Test 56 - E0 = No errors
Service Test 45 - Tray fills with water
Service Test 57 - Ice freezes, is successfully harvested, returns code 01 when complete.
So basically, if I use tests 45 and 57, I can make ice manually, it just won't do it on it's own.
Any thoughts or suggestions would be greatly appreciated!
