user21 said:
If I could figure what the valve is,
Your machine is a sequential cooling dual evaporator. It uses two separate evaporators and cap tubes. The 3-way valve directs the refrigerant flow to either the freezer evaporator or refrigerator evaporator which ever compartment is calling for cooling. Refrigerant flow is directed through only one evaporator at a time. Thus the word sequential. This is for a different machine but I believe the first five test are the same.
To enter Service Diagnostics: Press SW1 and SW2 simultaneously for 3 seconds.
Release both buttons when you hear the CHIME indicator.
The display will show 01 to indicate the control is in test 1 of the diagnostics routine.
Each test must be manually advanced. Press SW5 to move to the next test in the sequence. Press SW4 to back up in the sequence to the previous test
Each step is displayed in the two digits of the dispenser user interface display. The step results are displayed in the two digits on dispenser user interface display 2 seconds after the step number is displayed. An amber order filter light will be shown to designate that the step number is being displayed A red replace filter light will be shown to designate that the status of the step is being displayed.
To exit Service Diagnostics Press SW1 and SW2 simultaneously for 3 seconds, disconnect the product from power or wait 20 minutes. Following the exit of the diagnostic mode, the controls will then resume normal operation.
Service Test - 1: FC Thermistor
The board will check the resistance value of the thermistor and display flashes results on the Temp display
01 = pass 02 = open 03 = short.
Service Test - 2: RC Thermistor
The board will check the resistance value of the thermistor and display the results on the Temp display
Service Test - 4: Compressor/Condenser Fan Motor/ Evaporator Fan
There will be a delay of 3 seconds before start of Sub Step 01. NOTE: Each test is timed and will automatically proceed to the next step. User will not be allowed to exit test. If exit is attempted, an invalid chime will sound. Control the sealed system loads by selecting SW3
01 = initialize dual evaporator valve in home position (4 min.)
02 = close both RC and FC evaporator valves (1 min.)
03 = turn compressor on (1 min.)
04 = keep compressor on. Drive the valve to RC position and turn RC fan on
05 = keep compressor on. Drive the valve to FC position and turn FC fan on
Verify airflow from the evaporator fan.
NOTE: Advance quickly through Service Test 4 to keep from locking in. Once locked in, you cannot exit, and must wait approximately 10 minutes.
Service Test - 5: Compressor Status/Speed
Initial Display 02 = Minimum speed
Depress SW3. Display = 03. Compressor ramps up to maximum speed. When maximum speed is reached, 01 is displayed.
Depress SW3. Display = 04. Speed ramps down from maximum to minimum speed. Display = 02.
