BokeInNH
- KRSC500ESS00
- KitchenAid
- 1-5 years
This KRSC500ESS00 refrigerator is 5 years old. The first ice maker failed when it was 2 years old. When the tech replaced the ice maker,
I saw how easy it was to do. Tech said "these fail pretty often, you're lucky if you get 5 years out of it". He was right because the ice maker stopped working 3 years later, so here I am...
I bought a new ice maker and swapped it in (the old ice tray was stuck at an angle.)
Unfortunately the new one didn't work so I figured it was defective.
So sent it back and bought ANOTHER new one direct from "Whirlpool parts factory certified".
Installed second new one and still it is not working! Very frustrated, I have no ice even after 3 days.
The freezer is 0 degrees. NO WATER EVER ENTERS the ice cube tray.
The door water dispenser works fine and delivers water at the normal rate.
I also inspected the water inlet above the cube tray and see no ice buildup at all,
and I even ran a hair dryer into it to be sure the channel is not iced.
I have seen posts about broken wires at the freezer door base hinge but my wires look pristine.
The ice maker switch is ON, and I tested the bin sensor with success.
I have run the ice maker related diagnostics, with these results:
Test 44=2, then 23 ... when I initiate harvesting with SW3 I see "12", then "23"
test 45=02 (I can never do water fill test because SW3 does not respond!) <<--HELP!
test 46=00 (unrelated but it works, and when I dispense water I see 01)
test 47=02=open
test 48=02=bucket present
test 47=02=open
