Kitchenaid KRSF705HPS00 ice maker not making ice
txcool
Texas
KRSF705HPS00
My Kitchen Aid refrigerator, model KRSF705HPS00, has stopped making ice. There does not appear to be water or ice in the tray right now.
I regularly replace the filter. Not all the diagnostic codes are available (tests/codes 15, 36, 37, 45, 46 & 56 are not available options, for example).
Also the water dispenser is working fine...
Test 19 IM Fill Tube heater is on
Test 18 Ice door motor is closed
Any advice would be appreciated.
Thank you!
Here's your ice maker tech data sheet that has troubleshooting in it: https://drive.google.com/open?id=1cM55ONghMG_V99Hdd-ysfueTDjV9Uvsq
W10873791 Ice Maker
--->I'd first check for any frayed or broken wires underneath the freezer door--->Lots of members have found frayed and broken wires causing the ice maker/and or auger motor to be low voltage or dead completely. Remove your bottom kickplate grille, Remove the black wire harness loom too, broken wires can be underneath it.
Another member was having a similar problem here: FIXED: GSF26C4EXY02 Whirlpool Gold Ice Maker Problem Look at his post #6 he found frayed and broken wires underneath the freezer door, remove your kickplate and check for that first.
Here's another one with the same thing about the frayed and broken wires: FIXED: 106.51173310 Kenmore elite ice maker not working - no led light
Here's another: FIXED: Whirlpool WSF26C2EXF01 Door Icemaker Not Working
