rodneybarrett
- KSRS25ILBL02
- KitchenAid
- 6-10 years
I have a KitchenAid KSRS25ILBL02 side by side refrigerator and am having a problem with the freezer. The freezer is way to cold (measures -18 degrees) no matter what setting I use. The compressor does turn off periodically and the refrigerator is holding the right temps (i.e. diffuser seems to be working correctly).
I have also tried the diagnostics to check each of the thermistors and they are checking out ok.
I have had some issues with a plugged drain and the icemaker water line freezing but I think those were caused by the freezer running at a much colder temperature than normal. They have been since fixed with completely thawing out the whole frig for a day.
What are the next steps I need to take to trouble shoot the problem?
