toma6852
- KSSO42FMX00
- KitchenAid
- More than 10 years
I have a Kitchenaid refrigerator KSS042FMX00 vintage 2004. The ice maker (106 626667) is not working properly. I have looked at the unit, and discovered a small broken chip in the white rotating dial on the front. I thought this may be part of the ejector arm.??? Looking on YouTube, I see this is not the case as this part appears to be part of the dial on a different model 626640.??? I cannot find any information on model 106 626667, but instead find similar as in 626663, 6266640 etc. In addition our model has a white plugin jumper between L and T that I don't see in any other model seen on you tube. Any thoughts on that?
On testing
Here is what I know.
The water makes it to the tray, it freezes, the mold heater checks out at 72 ohms resistance, the power to the head reads at 120 volts N to L and it will rotate if jumper wired H to T. At this point I close the door and leave the ice to freeze. Two hours later the ice is still in it and the white drive wheel has advanced the fingers to the point they touch the ice in an attempt to push it out and its stuck. If the wheel is pushed in slightly by hand the unit will rotate but at that point I believe the mold heater hasn't come back on before I push the wheel in and its difficult to remove the ice because the cycle was broken. My feeling is most of the issue is end piece of the plastic fingers that extend into the wheel to hold it in place are broken off. But then again, why are they broken off? Did the mold heater not come on and the drive of the motor broke them off even though it tested OK at 72 ohms?
On testing
