fixmiester
- KUDS30IVWH3
- KitchenAid
- 6-10 years
Been having strange issues with not being able to start wash cycle, because one or more control panel lites mysteriously come on, either steady, or blinking. When this happens, I cannot clear the lite(s) with the Clear button. I initially had some success with unplugging the power cord for an hour, and it would sometimes solve the problem. But then it would come back. Started searching on line, and saw there was a diagnostic procedure I could run. Found my product support sheets inside the kick panel and read them carefully.
I did the full diagnostic cycle, and found that all the lites were functional at first, but there were a few discrepancies from the flow chart, I. e. some weren't coming on when they should have, and another (Washing) was staying on the whole time. Otherwise the diagnostic cycle fills, washes, drains and heats okay. Unfortunately, this model does not have a digital read out for error codes, so you really have to pay attention to when certain lites should be on/off, or even blink during the 18 different cycle periods (not easy because you can't be certain which period you are in, without a digital readout, and some of the cycle times vary, apparently).
I took apart the drain filter, the food grinder and the different screens and cleaned out everything (no clogs found), and it worked fine for a few days but then went back to same problem modes (which change from time to time). I even replaced the control board, reset everything and ran it through three loads with no problem, except the Drying lite never comes on after the Washing cycle, and it goes straight to Clean, and it is definitely steaming hot, and the heating element has been on..
So my question is this... Is there any way for me to correlate the diagnostic lite patterns to any useful component failure information, or am I just SOL and must resort to replacement roulette, and hope for the best? Any insight or recommendations would be appreciated.
