Kitchenaid Microwave Model YKEHV309 has "DOOR" error message
Rylynne145
kingston, ontario
YKEHV309
Door error code on microwave investigated and discovered all three switches test fine and fuse is good using ohm meter. At a loss as to what to do next.
I found YKEHV309PM01 & YKEHV309PS01
Door mechanisms that activate the switches check ok?
Door key(s) that activate the switches check ok?
Wiring to and from the switches check ok?
Maybe if everything else checks ok the board is no longer sensing the door being opened or closed??
I have little to no experience with these build in units.
jeff sr.
Rylynne145
kingston, ontario
Hi Jeff,
YKEHV309PM00 is the full model number..... meterite colour I think the last few digits are for.​
Wiring to and from the switches are a bit tricky..... I'm not sure what to look for exactly.
This problem occured sporatically at first then it came to the point where it would not work at all. The microwave would stop sometimes and door would come up.... we would open and shut the door and it would work fine.... eventually not working at all.
Anything pinched, discoloured, loose or burnt would be good place I would start.
YKEHV309PM00
Hey BB, do you have a manual for this one??
jeff sr.
