SSGWJL
- KSIB900ESS2
- KitchenAid
- Less than 1 year
I bought this KSIB900ESS Induction Range 6 months ago and it had worked great until last night. The oven will no longer heat, whether using bake, broil, convection or the bottom drawer. It stopped heating while baking after it had already heated to set temperature (350 degrees). Oven will show as preheating, but it is not. There are no error messages, it is not locked/on delayed start etc. I pulled the thermal fuse to check for continuity and it is good. The induction top works as it should…doesn’t seem to be any issue with control panel functionality. Any ideas as to what the issue could be/what I could check next? Can’t believe both elements would die simultaneously. Thanks in advance!!!
Added complete model number
