elrond
- KDRP463LSS08
- KitchenAid
- More than 10 years
I have a Kitchenaid Range/Oven KDRP463LSS08
I never should have put the oven into a cleaning cycle, but I did, and now all kinds of problems. The front of the oven, including the display, were too hot to touch when the oven ultimately shut down.
The display is not working and oven now appear doesn't function, no lights inside either. The gas stove portion still functions fine, including lighting the burners.
I have replaced the thermal fuse, and the inline fuse inside, both of which were destroyed. I also replaced the blower fan because it looked old and dirty. I pulled the panel off and inspected the wiring. Nothing appears to be melted, although they are covered in some strange puffy brown material that I can only guess is dust combined with grease, or insulation material that has burnt. I tried to re-seat some of the wires, but none of them seem to be bad. I have flipped the breaker too.
Any suggestions as to what to check next? How do you test the control board, and where would I even go to purchase a new control board?
