My KitchenAid refrigerator KRMF706ESS pantry buttons will not beep when attempting to change the selection and no indicator lights as well... Help please?
Your missing 2 digits at the end of your model number.
Here's the results I get:
KRMF706ESS00
KRMF706ESS01
KRMF706ESS02
KRMF706ESS04
KRMF706ESS05
Check for 14 volts DC at the wire harness electrical connector that connects to the Pantry UI Board. If 14 volts DC is not present, check the wire harness to it for any damaged or broken wires.
This video provides step-by-step repair instructions for replacing the pantry drawer wire harness on a KitchenAid 5 Door Refrigerator (Model KRMF706ESS01). Learn more from the experts at Repair Clinic.
Hello - I have a similar problem (along with the ice maker, water and lights issue you have already described how to fix). What are the wires to use to test for the 14V please? I have the KRMF706ESS01. Also, any pointers for keeping liquid out of that pantry drawer control panel spot?
Just yesterday the water dispenser quit working on our KRMF606ESS01 KitchenAid Refrigerator. At first the LED lights and the dispenser didn't work and the Code UAC was being displayed. I performed some troubleshooting getting into the service codes and some features began working again. Later...
www.applianceblog.com
You model uses that exact same tech data sheet his model does.
