Billymons
- KFIV29PCMS00
- KitchenAid
- 6-10 years
Kitchenaid KFIV29PCMS00 E05 error. ( timed ice making) French door style refrigerator. History is that 5 years ago the freezer evap and compressor were changed under warranty sealed system leak job, Sears. Its been good ever since. 2 years ago the ice maker quit making ice and I replaced the ice maker. Good since. Not sure if I had a error code then. Now I'm getting E05 (timed ice) I can unplug it and clear the fault and it will make one batch of ice and then eventually fault again E05.
I went through all the possible checks, motor works good and harvests and passes, IM heater passes, IM thermistor passes and I also checked the ohms at the pink and tan wires at the control board read 18,200 ohms which was (8 degrees). I believe it only needs to see 14 degrees to start the harvest?? Also checked water fill and it passes.(verified it filling) Ice box level, passes. Ice box thermistor, passes. I just replaced the IM again and still got the E05. Freezer temp seems fine around 5-10 degrees along with the IM box.
I hate to condemn the control board but I'm leaning that way. Oh and I replaced the IM fan because it sounded week. It would start out nice and then go to like nothing. What am I missing to check??? Is my freezer not cold enough? Set for 0 degrees and I don't think it ever gets there. Maybe getting low on r134a. Im a HVAC tech 30 years and Refrig is my weakness but I'm not a dumb cookie just need some guidance. Thanks in return. Is it common for these boards to go?
