- KRFC704FPS04
- KitchenAid
- 1-5 years
Good afternoon folks,
I recently purchased an open box Kitchenaid KRFC704FPS04. I've had the refrigerator for a few days now and everything works great with exception of the ice maker. I've followed another post on this forum trying to trouble shoot the issue. It simply looks like the water is not making it's way into the ice maker. The door water dispenser works fine, water pressure from the dispenser is good, water filter has been replaced.
I went into the diagnostic mode and run following tests:
#14 result: 22
#16 result: 32
#31 result: 2
#66 result: on
#79 result: 01 (ok)
#97 result: FF (I'm not sure about this one, does it mean off? no water making its way into the tray)
#115 result: 01
#120 result: PA
My best guess would be a faulty water valve, however if the water dispenser works, could that be an issue? Is there a separate valve for the ice maker alone? I don't see any sign of freezing at the water outlet located above the ice tray.
Thanks in advance !
#14 result: 22
#16 result: 32
#31 result: 2
#66 result: on
#79 result: 01 (ok)
#115 result: 01
#120 result: PA
Thanks in advance !
