- KRFF507ESS00
- KitchenAid
- 6-10 years
Hi - I'm new to this forum and hoping someone can help with what I think is a unique problem.
We have a KitchenAid French Door Bottom Mount Refridgerator (includes icemaker/water dispenser on left side). The refridgerator is just over 6 years old (model # KRFF507ESS00). For about the last year we will find a pool of water at the left front of the fridge on an intermidant basis (guessing from 1x a week at times to 1x a month at times). It always seems to occur overnight.
I"ve read that it could be because of a blocked drain but note there is no water inside the fridge and under the fridge appears to be dry. I've also noticed the drip pan seems to be completely dry which makes me think water isn't getting there to evaporeate which would seem to indicate a blocked drain.
Hopefully this next part isn't completely off base....recently I noticed (should have been sooner) a silicon type material at the left front (circled in blue in the picture). It seems to be a plug or seal of some sort and I'm wondering if the water is coming out of that. Is there water that runs along the front to get to the drip pan? It seemed a bit loose so I push it in but there is still water that appears.
Does the pooling of water coincide with an automatic defrosting?
Does it make sense that under the fridge seems to be completely dry?
Is that silicon material some sort of seal that has failed?
Do I have a plugged drain?
Anyway, I've searched Youtube and google and the issue we are having seems kind of unique and I'm hoping someone here has some suggestions.
