Bridgetalaniz
- KRMF706ESS01
- KitchenAid
- 1-5 years
Hello,
Diagnostic Question:
I am having a few issues with my KRMF706ESS01. Last year I have had the control board, and evaporator fan replaced, and now I am having an issue with giant ice blocks in my freezer due to a leak coming from the drawer shelf. After doing some research seems the issue may be the defrost drain, which I am in the process of trying to resolve. When following the document "Service Pointer - W11092686 - RevG - Frost Build up on Evaporator", it says to change the defrost setting, however I have option 1-6, then 8. I do not have the option 7 on my fridge? Is this normal?
Ice Dispenser.
So the motor is making a sound when trying to dispense ice, and it passed the dianostic. Ice is being made, and is in the icebox, however when I try to manually spin the auger connected to the icebox it does not move. Its like the bolt it connects to is stuck and will not move. Have you heard of this before? Is this a part I can replace?
Water Dispenser
The water is coming out from the spout in a horrible flow, not smooth at all and water droplets everywhere, is there a solution you know that will fix? I tried cleaning with vinegar, to no avail.
Ice Dispenser.
Water Dispenser
