KitchenAid Refrigerator KRMF706ESS01 ice maker not dropping ice. ice is present in the box
jennama
Toronto
KRMF706ESS01
Ice maker does not drop/ dispense ice when lever is pressed. ice gets made perfectly fine and there is ice present in the box. water also dispenses perfectly fine
Access the main control board and locate the P3 connector. Measure the voltage across P3-7 to P3-8 when the ice lever is pressed. LH RC door must be closed. Your meter should indicate 130-140 VDC. If the voltage is correct, replace the auger motor.
