Service Test - 56 Ice Maker Error Codes
• Displays active Ice Maker Error Codes on the UI display. (E0 = No Errors, E1 = No Cooling, E2 = Motor Lost Position, E3 = Heater Timeout, E4 = Dry Cycle,
E5 = Timed Ice Making).
--->E5 = Timed ice making. This code indicates the ice maker thermistor is warmer than 16° and the ice bin thermistor has been below 45° for 3 hours. An E5 can be the result of a defective IM thermistor, bin
thermistor, loose thermistor connection, ice box fan not running or a cooling issue.
Put a freezer thermometer in the ice maker compartment and tell us what it reads in 2 hours. Do you hear the ice box fan running?
Service Test - 45 Ice Maker Water Fill Test
NOTE: BEFORE INITIATION THIS TEST, GO TO STEP 57, INITIATE ICE MAKER HARVEST TO INSURE ALL ICE IS EJECTED FROM MOLD BEFORE FILLING.
• After an initial 3 second delay, displays the Ice Maker water fill stat on the UI display. Press SW3 to start a water fill. Pressing SW3 will toggle between ON and PAUSE. (02 = Off, 03 = On, 04 + Paused).
Service Test - 57 Ice Maker Harvest
• Press SW3 to activate a Harvest sequence. Digit 1 displays the state of the sequence. Digit 2 displays the outcome of the sequence. Once initiated, the sequence cannot be exited.
Digit 1 0 = Heater and Motor OFF, 1 = IM Heater ON, 2 = Motor Rotating CW until it finds home position.
Digit 2 0 = In Progress, 1 = Harvesting Completed, 2 = Harvesting not completed, Doors must be closed.
NOTE: Harvesting Not Completed does not exit the step, but indicates the timeout of 70 seconds has passed.
W11294907 Icemaker
