- KSCS25FKSS00
- KitchenAid
- More than 10 years
Hi all,
My KitchenAid Superba side-by-side freezer/fridge has a problem where the fridge temperature is fine while the freeze is not cold enough, 10-20F instead of 0F.
I have checked all the usual:
I assume it's a compressor or refrigerant issue which is beyond my skill level to change.
What do you think?
Please note that the unit is fairly old (15-20 years?) and about 2 years ago I had to change the compressor already, but before that everything was working just fine.
Is it worth calling someone to fix it?
- all fans are turning
- the compressor is hot but not super hot, and vibrating which I assume means that it's working
- I cleaned the coil under the unit
What do you think?
