Our wine cooler doesn't run. Compartment light comes on so it has power. Is there a way to check/change the compressor relay or check/change the thermostat? Other tips?
Parts for KitchenAid KUWS246ESS0: Section Parts in stock and ready to ship today. 365 days to return any part.
click.linksynergy.com
If you have an ohm meter you can check continuity on it, by removing the wires to it, and putting your ohm meter probes on it to see if you have continuity through it.
Unplug your wine cooler first of course.
You could also jump the wires on it to see if it starts running.
Great advice, very helpful. I used a multi-meter (had to buy one!), indicated an open circuit. I jumped the leads with a piece of wire (after plugging in the cooler) and it came on. I'll order a new thermostat today.
I have exactly the same wine cooler and the same problem. The Whirlpool repair man jumped the thermostat to get it running but it only worked for a day.
Its fairly simple to replace, just unplug the wine cooler then take the thermostat knob off, then unmount the thermostat and put the wires on the new one as they can off the old one.
Actually it comes with complete installation instructions.
